RossTRD Posted April 18, 2012 Posted April 18, 2012 My needle seems to bounce whenever the car is moving how can this be fixed? Quote
Taggy Posted April 18, 2012 Posted April 18, 2012 If its jumping its because the speedo cable is worn, you can get a replacement on here for about £15, just need to pull your clocks out and unscrew it from the back and the gearbox, refeed it through and screw back on. Fairly easy job Quote
StuDoc 72 Posted April 18, 2012 Posted April 18, 2012 Try taking out your speed cable and getting some oil down it make sure its nice and free should sort you out. Quote
RossTRD Posted April 18, 2012 Author Posted April 18, 2012 Thought it might be a faulty stepper as it was originally reading kph but converted to show what it would be in mph just don't have the right clocks that say mph Quote
StuDoc 72 Posted April 18, 2012 Posted April 18, 2012 Yes could be cable or the convertor. Cheaper convertors can become jumpy after time. Take your cable off and lubricate it and see if this makes any difference. Even try removing the convertor and putting the cable straight into the gearbox again tht way u know if its the cable or convertor. Quote
