kingo228 Posted April 22, 2012 Posted April 22, 2012 benefits of using ARP head bolts over standard ones (not running over a bar of boost) ?benefits of using a 1.2mm head gasket (not running over a bar of boost) ?When rebuilding my bottom end, should i renew the Rod bolts and nuts , as they are Stretch bolts? and can anyone get hold of these?any porting i can do on the bottom end to improve oil flow ?Best oil to used when running in ....and then oil to use once run in is complete?are the whole engine gasket sets the same for ep82 and ep91 ?think that all for now thanks very much guys Quote
Azz Posted April 22, 2012 Posted April 22, 2012 Stretch bolts need to be re-newedall you need can be bought from Iddy @ Id works Quote
conz1 Posted April 22, 2012 Posted April 22, 2012 I think the standard head gaskets are 1.2mm but if you were to go a bit bigger such as 1.4 or something you'd slightly lower the compression. Quote
kingo228 Posted April 22, 2012 Author Posted April 22, 2012 oh thought the standard head gasket was like .9mm Quote
DevonGT Posted April 22, 2012 Posted April 22, 2012 Don't need ARP head bolts and standard headgasket will be ok for 1bar.AFAIK gasket sets are different. Quote
starletburkie Posted April 22, 2012 Posted April 22, 2012 stock gasket is 1.0mmstock bolts and gasket will be ok even at 1.2bar on td04 they will still be up for the job, rod bolts dont need to be renewed and gasket sets are the same Quote
conz1 Posted April 22, 2012 Posted April 22, 2012 When I was looking at headgaskets a lot of them said standard 1.2mm head gasket, so I just assumed they were 1.2 mate . Quote
