triple j Posted April 22, 2012 Posted April 22, 2012 as above can anyone tell me the lenght of there td04 oil feed, thanks Quote
Flaminsam Posted April 22, 2012 Posted April 22, 2012 I had one made last friday. 14mm banjo, 10mm banjo and overall length 500mm. I had it made at pirtek and cost me 30. Was made from 3/8 stainless ptfe hose and was guarenteed also. Quote
triple j Posted April 22, 2012 Author Posted April 22, 2012 i ordered 250mm lenght but am using an adapter plate so the turbo will sit lower, do u think it will be long enough. Quote
Flaminsam Posted April 22, 2012 Posted April 22, 2012 Could be a lil tight. I'm sure it will be fine though. I've got quite a bit of slack left on mine. Quote
triple j Posted April 22, 2012 Author Posted April 22, 2012 hopefully its ordered lol, will the line fit from the block up behind the turbo to its m10. Quote
Flaminsam Posted April 23, 2012 Posted April 23, 2012 Mine is around the front. Yea it should fit from the back of the turbo. May be a bit snug though. Quote
