Pros and Cons of Removing ABS from a high powered starlet?
As above folks. Looking for the advantages and disadvantages of removing the ABS completely from a high powered starlet? I have seen it done before but hear mixed opinions on it.
Thanks in advance,
Browner.
Less wiring, modulator can be removed brake pipes remade out the way, when you knacker up a cv it's either A cheaper to buy cv joints B you don't have to mess around warming the other one up to remove, edit the reluctor rings I'm on about
Speed sensors can be removed.
And you could use the fixing hole to mount another sensor to work along side launch control to measure wheel spin on a driven wheel so it knows when to stop working
If any of that makes sense
Edited by yaristurbo
