Flaminsam Posted May 4, 2012 Posted May 4, 2012 firstly not sure if im posting this in the correct section but mods feel free to move it. i have fitted a profec b spec 2 to my starlet td04l set up. when i drive down the road it will not boost past 0.2 bar. i have checked gaskets and none are blowing, ive even removed the boost pipe from the turbo to make sure im getting boost. ive also held my hand over the intercooler piping with the engine running and the engine just about stalls. (proves the intercooler piping has no leaks)so basically i would like to know if anyone has the same boost controller and how they have set theirs up. im using a stock wrx actuator with the boost signal side going to the NO side of the solenoid and the actuator piped up to the COM side of the solenoid. the solenoid works as it should also.so now i know my boost controller is plumbed in correctly and the solenoid works it can only leave the settings on the controller. any ideas?? Quote
Flaminsam Posted May 5, 2012 Author Posted May 5, 2012 Ok so turns out the shaft on my tdo4 is bent. Taking it back to the breakers on Tuesday to see of they will exchange. Quote
Flaminsam Posted May 5, 2012 Author Posted May 5, 2012 Nope more expense. We will see if the breakers I got the turbo from will be understanding. If not I only paid 40 for it. Quote
