Well my car decided to chew through my hid wire the other day they arent fixed so they slipped and burnt through the big red wire on the hid! i seperated the 2 wires inside so they wernt touching and taped it up still not working, i thought a fuse might be gone and i was right so replaced that and still nothing ! it flickers when i switch them on but thats it ! any info on what else to do !!
depends what kind of lights you have are the broken wires before or after the ballast if they are between the ballast and the bulb then your not supposed to repair them because they run about 60,000 volts so that also could be your issue. But ballasts i think are about 30 or 40 quid
