Rich Posted May 29, 2007 Posted May 29, 2007 First Question:Well when i've been out for a drive then open my bonnet I get this buzzing noise coming from the engine bay, it seems to be coming from one of the black cilinders at the back near the air box. Does anyone know what this could be? It doesnt seem to do it when its cold though.Second Question:Is the topic about gutting the cat on ep91 the same for an N/A 91 or is that just for the glanza?Thanks, Rich. Quote
Guest Enzo Posted May 29, 2007 Posted May 29, 2007 il answer your questiion, you cant legaly gut the cat on an na because they were available to buy over here,so the glanza can get away with it legaly, the na cant;) Quote
Rich Posted May 29, 2007 Author Posted May 29, 2007 Yeah, but is the way to do it the same... or best just getting a decat made up? ;) Quote
Glanza_Ragger Posted May 29, 2007 Posted May 29, 2007 If the n/as have a honeycombe style catalyst inside, chisel it out. It will pass the visual cat test on mot but it may fail emissions.Best having a new pipe made then swap for mot time.can you figure out which cylinder is buzzing along with a picture mate ? Quote
Tintin_SR Posted May 30, 2007 Posted May 30, 2007 If the n/as have a honeycombe style catalyst inside, chisel it out. It will pass the visual cat test on mot but it may fail emissions.Best having a new pipe made then swap for mot time.can you figure out which cylinder is buzzing along with a picture mate ?I my sr has this problem as well think its from the fuel filter!! Quote
Mart Posted May 30, 2007 Posted May 30, 2007 Mine buzz's aswell. Its from the black cylinder from the back of the engine bay just behind the Air Filter Box. Its normal as far as Im aware. Quote
Rich Posted May 30, 2007 Author Posted May 30, 2007 oh well least im not the only one ;), it doesn't seem to cause any problems, ;) was wondering just in caseAnd the cat question, Is the way to get the cat apart the same? the heat sheild is removeable but didn't remove it because I didnt have the right tools on me, but it seems like the cat itself is welded to the rest of the exhaust. Quote
Tintin_SR Posted May 30, 2007 Posted May 30, 2007 oh well least im not the only one , it doesn't seem to cause any problems, was wondering just in caseAnd the cat question, Is the way to get the cat apart the same? the heat sheild is removeable but didn't remove it because I didnt have the right tools on me, but it seems like the cat itself is welded to the rest of the exhaust.i it ia a weld job i just haked the old cat off an welded a bit o pipe in it it bud its good Quote
