Azz Posted June 22, 2012 Posted June 22, 2012 Hi, Does anybody know what size the depo water temp sensor is ? ie thread and diameterCheers Aaron Quote
Azz Posted June 22, 2012 Author Posted June 22, 2012 its 1/8 NPT fitting dude!mike.Is that different to 1/8PT? if you know Quote
Michael! Posted June 22, 2012 Posted June 22, 2012 Is that different to 1/8PT? if you knowNot sure on the difference mate sorry, but thats what depo quoted in the instructions when i bought my water temp gauge 1/8 NPT! Quote
Azz Posted June 22, 2012 Author Posted June 22, 2012 Not sure on the difference mate sorry, but thats what depo quoted in the instructions when i bought my water temp gauge 1/8 NPT!Ye i lost my instructions from mine, i bought an adapter which is 1/8PT and does'nt fit so weather its the adapter or sensor is nackered i dont know Cheers for that anyway matey Quote
Michael! Posted June 22, 2012 Posted June 22, 2012 Ye i lost my instructions from mine, i bought an adapter which is 1/8PT and does'nt fit so weather its the adapter or sensor is nackered i dont know Cheers for that anyway matey I bought a adaptor for mine of buddlyclub website, and that was again 1/8 npt and fitted bang on! Is it tight wen ya screwing the sensor into the adaptor??Mike. Quote
Azz Posted June 22, 2012 Author Posted June 22, 2012 I bought a adaptor for mine of buddlyclub website, and that was again 1/8 npt and fitted bang on! Is it tight wen ya screwing the sensor into the adaptor??Mike.Im going for the small screw in adapter the goes were the ac water used to be, like this http://www.ebay.co.uk/itm/120578950493?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 but the sensor wont even start to screw in Quote
james@cjperformance Posted June 22, 2012 Posted June 22, 2012 Npt and np are the same dude. they will be a really tight fit as it will hold water failing that i can send you a replacement sensor in exchange for that one Quote
Azz Posted June 22, 2012 Author Posted June 22, 2012 Npt and np are the same dude. they will be a really tight fit as it will hold water failing that i can send you a replacement sensor in exchange for that one Cheers dude, il have another go but tight is an understatement and i dont want to damage the threads Quote
Azz Posted June 22, 2012 Author Posted June 22, 2012 no worries let me know Well just checked it James, you can get the sensor 1/4 of a turn into the adapter then it goes solid Quote
Michael! Posted June 22, 2012 Posted June 22, 2012 They could be 2 diff thread pattens i.e sensor and screw in adaptor, or cross threaded! Makes sure when ya do sort it to put some PTFE round the thread before ya screw it in, just so its 100% water tight mate!Mike. Quote
james@cjperformance Posted June 22, 2012 Posted June 22, 2012 should wing in dude, will need a spanner to do so though, the threads are tapered aswell making it harder to turn., i would advise using a small aamount of ptfe tape so it seals correctly Quote
Azz Posted June 22, 2012 Author Posted June 22, 2012 should wing in dude, will need a spanner to do so though, the threads are tapered aswell making it harder to turn., i would advise using a small aamount of ptfe tape so it seals correctly So just get some force on it then bassically??? Quote
Michael! Posted June 22, 2012 Posted June 22, 2012 Not to much force dude, ya dont want to damage the threads, if it feels like it dont want to go dont force it!! Quote
Azz Posted June 22, 2012 Author Posted June 22, 2012 you got it Well just had a go, not much force at all and the sensor has snapped in half so im up s*** streak now Quote
james@cjperformance Posted June 22, 2012 Posted June 22, 2012 Hmm if you send me the link to the adaptor you bought ill get another and try it and send that and a new sensor out to you amjads was tight as hell and needed a kick up the arse Quote
Azz Posted June 22, 2012 Author Posted June 22, 2012 Hmm if you send me the link to the adaptor you bought ill get another and try it and send that and a new sensor out to you amjads was tight as hell and needed a kick up the arse Now thats a trader for you showing the uksc love, cheers dudeHeres the link mateyhttp://www.ebay.co.uk/itm/120578950493?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648 Quote
