Can anyone recommend Me a garage in the southwest close to taunton
Had my car in the for the same oil leak three times at my local garage and got it back yesterday told all is well it was dry for a day and took it for a run same thing again :(
No don't think I no it but will enquire you got a number for this chap basically what was suppost to be. a crankcase oil seal has turned into a nightmare and I'm at the end of my tether with the car :(
Not sure mate it started off as a crank case seal and cam shaft seal they have had it back 3 times taken my Roose ancillerys off blaming that for the leak then my dump valve and last of all had my rocker cover off and apparently that and some sort of plug on back of the engine was causing it but after all that bull its still leaking sucks man
Bad luck is an understatement had the car a year now and spent thousands replaced engine gearbox and just about everything else possible to get a clean base to work on but back at square one bad times
It's gone back in I'm giving them one more chance to sort it fingers crossed :D
Thanks for the offer mate you local to Taunton ?
I'm having my clutch fitted Friday at a garage I've never used before in Weston behind Asda if they are good il drop you there email address and number if it doesn't get sorted this time mate :)
  • 2 weeks later...
Can anybody advise we're I can get a sump in good nick or a new one for a reasonable price seen them on camskill but pretty steep for a sump I think
Thanks
I.completely forgot about this sorry mate :( I would deffo recommend the garage I used .... The mot center, Warne road, Weston super mare if you google it your find it :) they helped me out and did a perfect job :)
And I'd wack up a wanted thread :) maybe your best bet :)
James
