Hey there guys,
Can anyone tell me the thickness of the el'sport c-pillar brace?
Need to get a camera mount for it but does not know the thickness of the brace cause my car is not around for now so i have to ask you guys.
cheers
Just measured mine for you mate - Its just under 40mm approx 39-40mm give or take.
Its not the easiest thing to measure as its not an open tube.
So a camera mount that is slightly adjustable around that diameter will work spot on, have done it myself with an ebay cheapie that had loads of adjustment.
Hope this helps :)
Joz
thanks dude that helps allot, just checking out wich camera mount size i need. Found one but now i know that the size doenst match up. So have to search for another one ;)
normally i measure such kind of tube measurement with a Mitutoyo tool. Now i dont have to make allot of miles for measuring only. saves up allot of petrol :D
No worries man :) Its not that thick of a tube so you should be able to find a nice mount.
Just to confirm mine is an El'sport so all should be good :thumbsup:
Joz
