Hi there guys. Hope you can help me out?
Im running without boost at the moment.
This afternoon i where ragging to 210km, lift my foot. Hole in the manifold, hearing the leak exhaust sound.
ok no boost cause a focked mani. This evening i changed the manifold to a new one. bolted everything together, no leaks or so whatever. Blitz EBC display is working and giving only vacuum measurement at the moment. No boost coming up.
Gonna search for the boost solonoid tomorrow, maybe i still got it. Actuator i can pul so not stuck. Got the battery out the now for a system reset.
What other possibilities are there?
ps Blitz ct9
They where still attached. the same as before. Actuator on IN and the turbo nipple connected to OUT on the solonoid. it looks like iam only using the ebc as boost gauge.
Drove full boost, let go the pedal. Few secs later there was a crack in the mani. no boost. ok mani is dead thats why there is no boost. changed it and did not touch any hoses or something.
can it be that the ebc sprung into save mode and shutted down the solonoid?
System reset Check
Turbine wheels spinning Check
Warmed up engine Check
Got BOOOOOST again :D
It looks like the boostcontroller (solonoid) has sprung into save mode just after the mani blew yesterday.
Only thing i did is that i disconnected the battery last night.
