hello people i have a glanza 1996
im looking to get some alloys
will these fit my car 7jx15 ???
these are 4 stud alloys
the man said If yours are a 6 or 7j then they will fit if lower they will fit but will require spacers
can any 1 tell me if these will fit my glanza turbo
thanks for your help
people
Welcome to the club
Depends on the PCD of the studs, the PCD you need is 4x100, also the correct offset would be needed due to the width of the wheels, The correct offset would be ET38
You may get rubbing on full lock though ;)
Hope this helps :)
