Hi all,
Can anyone please tell me where a boost gauge should actually be fitted, as in, where the piping should cut into the system?? As I never fitted the one I have now as it was already fitted.
Pictures would be much appreciated, thanks
Josh
i think there was a thread about this, on the back of the inlet manifold there is a pipe a couple of centimeters long and it goes in there for the best boost reading anyway i may be wrong tho
just done mine as the guy had wired mine in wrong, he had put it into the idle control valve vac. you just need to T into you map sensor vacum gives you -psi off throttle and 0-boost pressure on throttle:)
red line^^^^ splice into that
