Ok so going to be fitting my EBC this week and need a few of questoins answerd,
What spring do need in my wastegate if i want to run 0.7 and 1.1 bar through my EBC?
Where does my pressure sensor go ? ( not my solenoid valve )
What hole does it connect too on my wastegate ?
Cheers Aaron
Edited by Azz
Im not an expert but spring wise you need anything below what youd like to run so if you want 0.7 bar cud have a 0.6 bar or 0.7 bar spring and use the EBC to run 1.1. as for the valve im not sure sorry.
You want as strong spring as possible, don't forget you can't run lower than base spring pressure. I would stick a 0.7 bar spring in there, and just use the EBC to run 1.1 bar, and turn it off when you want to run 0.7
