Ok so going to be fitting my EBC this week and need a few of questoins answerd,
What spring do need in my wastegate if i want to run 0.7 and 1.1 bar through my EBC?
Where does my pressure sensor go ? ( not my solenoid valve )
What hole does it connect too on my wastegate ?
Cheers Aaron
Edited by Azz
You want as strong spring as possible, don't forget you can't run lower than base spring pressure. I would stick a 0.7 bar spring in there, and just use the EBC to run 1.1 bar, and turn it off when you want to run 0.7
