Hi,
I need some help with wiring up my oil pressure and temperature gauges.
It has 4 wires each.
1 signal
1 Ground
1 12v
1 illumination
Now the Signal and Ground I understand.
The illumination should be spliced in the wire which feeds the daytime running lights.
The 12V should be spliced in the wire which is the "On" function on the ignition barrel.
Does anybody know which collours these wires are?
Ignition:
Illumination:
Hope someone can help me in the right direction.
Is the 12v just for power to the gauge or does this illuminate the gauge also?
Is the illumintation wire only to illuminate the gauge or does it act as a dimmer for when you turn on your lights?
Not quite sure, they are STRI gauges.
All it says in the manual is 1x signal, 1x ground, 1x 12v "on" and 1x illumination.
I'm guessing that it has illumination and 12v separated.
Cool check what the 12v and illumination do but if the 12 is just for power to the circuit and ill is for the light then just wire both to the back of the cig lighter.
on my defi's they are this way round
1 signal
1 Ground
1 12v
1 illumination
Defi's
2. ignition live/ switch 12v when ignition is turned on
2. ground
2. 12v battery feed- constant
2. illumination - take an wire that comes on when you tuurn on your sidelights
you can take the ignition live and constant live from you stereo, live is normally yellow and switched is red
ground well thats any point you can earth the cable too or use an existing earth wire, if your desperate use the stereo one
sidelight feed is green i think coming from the side light stalk
Edited by Broony
The wire coming down your steering column that has 12v when sidelights are on and 0v when they are off. You can put your live and earth to the cig lighter and signal to the sensor ofcourse.
Yeah sidelight feed is green or green black like broony said its one of the chunkier wires in tht plug just test it with a multimeter and make sure u test it with the indicators on I made that mistake and my indiglo dials were flashing when i turned right haha.
Edited by StuDoc 72
