I know the stock CT9 turbo is small and onlty good for 1.0bar, is there any larger, better turbos which will be a bolt on replacement without having to tune anything else? If there is how much more bhp can you expect?
Just bolting an uprated turbo on will achieve nothin bar blowing your engine to bits!
I take it you're new to the whole turbo thing??????
Save the cash first then sort braking,suspension then fueling and cooling before bolting on a more efficient turbo then you can talk about getting gains.
Do it cheap...do it twice! :D
Wise words there :D
First- handling
Second braking
Third- exhaust/ filter
Fourth- FMIC and fuelling mods
etc etc depends how far you want to go B)
Thats a rough idea just dont go bolting a different turbo on and upping the boost expecting it to fly!!!
hey mate you need to get around fual cut before you will get by the limits of your turbo.
after that you could go the hybrid route whichi will enable you to run more boost.
there are a whole range of turbos that fit but the most comon would be a td04 kit
