Marc Posted June 14, 2007 Share Posted June 14, 2007 I know the stock CT9 turbo is small and onlty good for 1.0bar, is there any larger, better turbos which will be a bolt on replacement without having to tune anything else? If there is how much more bhp can you expect? Quote Link to post Share on other sites
ecksjay Posted June 14, 2007 Share Posted June 14, 2007 search on here and tgtt mate, been discussed many times obviously. Quote Link to post Share on other sites
paul w Posted June 14, 2007 Share Posted June 14, 2007 Just bolting an uprated turbo on will achieve nothin bar blowing your engine to bits! I take it you're new to the whole turbo thing??????Save the cash first then sort braking,suspension then fueling and cooling before bolting on a more efficient turbo then you can talk about getting gains.Do it cheap...do it twice! Quote Link to post Share on other sites
Sparky Posted June 14, 2007 Share Posted June 14, 2007 Wise words there First- handlingSecond brakingThird- exhaust/ filterFourth- FMIC and fuelling modsetc etc depends how far you want to go Thats a rough idea just dont go bolting a different turbo on and upping the boost expecting it to fly!!! Quote Link to post Share on other sites
Guest Enzo Posted June 14, 2007 Share Posted June 14, 2007 hey mate you need to get around fual cut before you will get by the limits of your turbo.after that you could go the hybrid route whichi will enable you to run more boost.there are a whole range of turbos that fit but the most comon would be a td04 kit Quote Link to post Share on other sites
