PhilGT93 Posted September 5, 2012 Share Posted September 5, 2012 could anyone please tell me how to wire in a 3 bar map sensor i need to wire it in on an ep91 so i can get my emu up and running but don't have a clue how to any help or pictures would be very much apreciated thanks guys :D Quote Link to post Share on other sites
AdamB Posted September 5, 2012 Share Posted September 5, 2012 Which map sensor is it? Different map sensors have different pin outs. If it's a greddy one it should be plug and play to the ecu as long as you have the field harness. Quote Link to post Share on other sites
PhilGT93 Posted September 5, 2012 Author Share Posted September 5, 2012 it is the greedy one mate just plugs into the ultimate but where does it go on the engine loom or anything ?and im getting the plug and play harness for the full emu as i dont like splicing Quote Link to post Share on other sites
AdamB Posted September 6, 2012 Share Posted September 6, 2012 If its direct plug into the EMU then all you will need to do is mount it, run a vac hose from the inlet mani to the map sensor, and ensure that the map sensor is plugged into the ecu Quote Link to post Share on other sites
PhilGT93 Posted September 6, 2012 Author Share Posted September 6, 2012 awsome mate cheers so T it off on the same line as the boost gauge would work? Quote Link to post Share on other sites
Hawwy Posted September 6, 2012 Share Posted September 6, 2012 Do it from behind inlet Quote Link to post Share on other sites
Broony Posted September 18, 2012 Share Posted September 18, 2012 On 9/6/2012 at 5:57 PM, PhilGT93 said: awsome mate cheers so T it off on the same line as the boost gauge would work?Simple answer: yesor you can t in where the stock map sensor is and mount it in the same place. Quote Link to post Share on other sites
