Hi when my wheels are straight the steering wheel is off to one side,
I hit a kerb on the snow 2 years ago and it's been like it since, I wasn't going fast but was on nearly full lock
I'm gonna change the lower arm, will it likely of bent the track rod end to?
Also is it worth changing the ball joints?
I just want the car to feel solid again on the front end :)
There new wheels to the ones that were on it as I smashed the rim!
I can see a slight bit of paint flake right in the bend of the lower arm indicating its bent so it I change that and track rod ends will that put the wheel straight if that's the problem?
Thanks for your advice mate
