GROUP BUY
Autobahn Front Mounted Intercooler Kits for EP82 GT and EP91 Glanza - £299.00 Inc Mainland UK Delivery
Please see below for more information regarding the above available item:
Application: EP82 GT and EP91 Glanza
Description: High quality intercooler kits by Autobahn. Very similar to the Blitz LM kit for the half the price. Includes everything needed for complete installation:
- Front Mounted Intercooler
- Direct Fit Pipe Work
- All Silicone Joiners
- All Jubilee Clips
High quality coolers made from 6061 aluminium and the core is 100% vacuum brazed. The polished aluminium end tanks are hand TIG welded for a perfect fit. The ambient fin pitch has been adjusted to provide an optimal fin density of 15 fins/inch. This gives the intercooler excellent flow properties as well as a large cooling surface area, and the efficient core takes advantage of these properties.
The four threaded mounting points along the top and bottom of the intercooler make installation simple. The intercooler core size is a massive 600 x 260 x 70MM and has a pressure drop of only 0.2psi @ 15 psi. The intercooler is polished aluminium with a Bar and Plate design.
The pipe work is polished aluminium. ABS and air conditioning do no not need relocated or removed. The quality and fitment of this kit is similar to much more expensive fmic's on the market like Greddy, Blitz and HKS, in most cases this front mount intercooler is larger and more efficient. ~9.2KG in total weight!
Features:
* Fully polished side tanks
* Tabs on bottom and top for easy installation
* Improved Bar and Plate to increase performance efficiency
* Core size 600mmx260mmx70mm
* End to end 780mm
* Inlet 75mm (3 inch) O/D
* Outlet 75mm (3 inch) O/D
* Supports more than 650HP
* Latest unique Bar and Plate core design to improve air velocity by 16% over the old design
* Fully polished alloy intercooler
* Ultra low pressure drop 0.5-1psi at 23psi (Normal Bar and Plate 2.8- 4 psi at 23 psi)
* 35 % weight reduction
* The kit will not only dress up your engine bay but will also allow for the much better air flow maximizing cooling efficiency on your Starlet.
High quality kit for a very reasonable price, please see below for group buy information.
Payment & Information:
This group buy is available for 5 or more TGTT members.
We accept paypal (4.1%), bank transfer and cheque which ever is convenient for you. To make payment or if you need any more information then don't hesitate to contact us via U2U or email: toytuning@toytuning.com
You won't have to wait for other members to pay before you receive your item.
Many thanks,
Toby
Update:
1. Garf (EP82 GT)
2. Bullet (EP91 Glanza)
3. Stu0500 (EP91 Glanza)
4. Pillzy (EP82 GT)
5. Baarsie (EP82 GT)
6. AndyGT (EP82 GT)
7. Squeekyduck (EP91 Glanza)
If anyone wants to be included don't hesitate to contact us.
Best Regards,
Toby
  • 1 month later...
Update
1. Garf (EP82 GT) - Paid
2. Bullet (EP91 Glanza) - Paid
3. Stu0500 (EP91 Glanza) - Paid
4. Pillzy (EP82 GT) - Paid
6. AndyGT (EP82 GT) - Paid
7. Squeekyduck (EP91 Glanza) - Paid
8. starletgt-shady(EP82 GT) - Paid
9. MJA (EP82 GT) - Paid
10. Elaine (EP82 GT)
11. Ross (EP91 Glanza - Paid
  • 1 year later...
