RobertR Posted October 26, 2012 Share Posted October 26, 2012 Hello Starlet enthusiasts,First, my apologies for any bad English I might use as it is not my native language (I am from the Netherlands).I am almost done restoring my Glanza, one of the problems left is that oil is leaking out on the right side of the axle housing (not sure what it is called, but it holds the differential). So I need a replacement oil seal but I can’t find the correct part number .I have the Toyota Japanese EPC and after searching that, I thought that part number 41336-12010 (found on the axle diagrams) was the oil seal. Turns out it is just the cover.In the picture below (from my car) I have visualized the problem area. Oil is leaking out the blue area of the housing, There is an oil seal in there (I guess), and I need the part number for that oil seal so I can order that from the Toyota Dealer. Links to other shops that sell those seals are also welcome!Further information: I do not have a LSD (LimitedSlipDifferential).I really need that part number, so I can put my Glanza back on the road! Thanks in advance!Kind Regards,Robert Quote Link to post Share on other sites
Idrees Posted October 26, 2012 Share Posted October 26, 2012 HiSounds like you need a driveshaft oil seal, we have them in stock and ship internationally PM coming your way mate RegardsIdrees ID-Workz Quote Link to post Share on other sites
klyfax Posted October 27, 2012 Share Posted October 27, 2012 (edited) Use toyodiy.com instead of JP EPC. Same number, English description.But your local Toyota dealer have Microcat now, not EPC. Microcat have all Toyotas model, EU, USA, JP, all model. So it should not be a problem for the local Toyota dealer to find and order a driveshaft seal for you.But ID-workz is cheaper than Toyota Denmark and Sweden. Edited October 27, 2012 by klyfax Quote Link to post Share on other sites
RobertR Posted October 27, 2012 Author Share Posted October 27, 2012 I already ordered it from Idrees! But thanks anyway! Quote Link to post Share on other sites
