Got the GT just wonderin how to remove the factory cd player! I cant find anywhere to grab a hold of it or even pin holes to use removal keys. Anyone got pics or a guide on how to do it?
if you pull the 2 nobs off the heater controls then use a screwdriver to pull the heater control unit out, there is 3 screws which hold the front of the panel on remove them and then pull the 3 wires for the hi-low boost, hazard warning and rear window demister. the panel will then come off, next remove the 4 screws whichhold the stereo in and you are done.
Cheers pal, will get that all switched over maybe next thursday/friday, are the screws star or are they torx screws?
