i dun an Engine Diagnostic Check before and got 33??? its not on the list think its the mass airfolw sensor but i put in an nother one and its still saying it and i was reseting the ecu each time. and its using so much petrol its un reel like a 3.3l v8 or sumit :wub: help??
tintin
Sure its defo 33? You letting the lights flash long enough? You using the toyota manual for the codes? I can check in work if you want?
i was using sumit that my brow got me from work but the one on hear hasnt got a 33 :wub:
i will try agen and see wat cums up
tintin
Auto-data? If so its pish. bridge out E1 + TE1 on the diagnostic plug, count the f;ashes and see if its the same :wub:
Ill have a check in work 2morrow
i thats wat i have dun and just agen ther and its defo 33
Shit mate sorry, ill try and remember for 2morrow (my memorys shit, ask sparky lol)
na its ok bud no rush thanks mun
tintin
  • 2 weeks later...
Code 33 - Idle speed control valve. Check your ISC valve first then go onto the idle control valve :p
kool thanks :p in that in the throtal body?
