I have a greedy oil cooler kit for ep91 if I have the cooler position horizontal will it affect oil flow
Here's the teaser pics !!!!
It's ment to be like this but on the other side but can't put it there as the turbo sits there
Also the two poles have nuts welded on each end for top frame support and to screw the aero catch pins into and get support from the lower frame it's just that it sits very good like this to the eye and function wise
Rant over and pls comment
Edited by glanzagee
Should be spot on dude the oil gets pushed through the same way no matter what way its mounted. I've your old one dont I lol?
edit just make sure all the air is bled from it maybe hold it sideways first run oil through it to get the air out then it should be ok to mount it upside down.
Edited by Corey
