loguey Posted November 7, 2012 Posted November 7, 2012 Was looking under my sr the other day and noticed a bit of rust bubbling through on one of the chassis legs, but its just along side the fuel tank. So gonna need to drop it and go for a full schutz underneath, any one ever run into any issues removing the tank before? Quote
Wardy Posted November 8, 2012 Posted November 8, 2012 I had a look at doing mine the other day, looks fairly straight forward but only advice I will give you is drain the tank first as it will be pretty heavy if your on your own and you done want that coming down on you! Use a jack or something with some padding just to take the weight Quote
