ep-beast Posted November 15, 2012 Share Posted November 15, 2012 as above took this out of an integra and it was wired in behind the radiotheres four wires out of the boxred black white orange any info on were to wire these thanks Quote Link to post Share on other sites
Broony Posted November 15, 2012 Share Posted November 15, 2012 (edited) on my defi's they are this way roundDefi's2. ignition live/ switch 12v when ignition is turned on ORANGE2. ground - BlLACK2. 12v battery feed- constant RED2. illumination - take an wire that comes on when you turn on your sidelights WHITECARSIDEyou can take the ignition live and constant live from you stereo, live is normally yellow and switched is redground well thats any point you can earth the cable too or use an existing earth wire, if your desperate use the stereo onesidelight feed is green i think coming from the side light stalkuseful diagram: Edited November 15, 2012 by Broony Quote Link to post Share on other sites
ep-beast Posted November 15, 2012 Author Share Posted November 15, 2012 thanks lad ill give it a go:) Quote Link to post Share on other sites
