Hawwy Posted December 17, 2012 Posted December 17, 2012 Will they fit15x8 et 30 arches are rolledWill fit 195 tyres so slight stretch tooStretch can be seen at http://tyrestretch.com/8_195_45_R15/8_195_45_R15_Toyo_Proxes_T1R_2.jpg.php. Quote
Starbo Moorley Posted December 17, 2012 Posted December 17, 2012 I ran 195/40s front and 185/45s rear on my 16x8 et10 rotas and only caught on the back right cause i dont run an adjustable panhard rod, i ragged the crap out of it too, i flared my arches too. This is on a Gt. Quote
Hawwy Posted December 17, 2012 Author Posted December 17, 2012 Mine are rolled but when they roll they pull out a bit fronts are not tho butI had a set off bbs split rims and they were 8.5 rears and 8 front with 195 45 15 and they went under the arch by jacking the rear axle up if that makes a difference. Quote
Starbo Moorley Posted December 17, 2012 Posted December 17, 2012 Yeh i raised mine at the back too help stop the catching. Got any pics with tge 8.5's on ? You runnin an adjustable rear panhard rod ? Quote
Hawwy Posted December 17, 2012 Author Posted December 17, 2012 No im not and il have to find it only had the one pic 2 mins il get it Quote
Hawwy Posted December 17, 2012 Author Posted December 17, 2012 In this thread but car needed to get more lowered in that that was jus a little test fit/>http://www.ukstarletowners.com/index.php?showtopic=55082&view=&hl=&fromsearch=1 Quote
Starbo Moorley Posted December 17, 2012 Posted December 17, 2012 If you lowered that itd catch occasionaly, im on the hunt for 9j's now so ill probably have too cut my arches, but i plan on running 205's or 215's depending on clearence. Quote
Hawwy Posted December 17, 2012 Author Posted December 17, 2012 Okay so as first post you think they will be okay 15x8 et30 Quote
