Ah right cant find a picture... But any way, the vacum hose from ontop of the regulator goes into your inlet manifold.
The petrol hose from the bottom of the regulator goes to your fuel return line.
The line on the side of the regulator goes to youre intake line.
http://i2.photobucket.com/albums/y26/saxor...pg?t=1183831193 (copy and paste into address bar, the img tags arent working for some reason)
So on that picture , The left hand feed is youre intake feed.
The feed going out from the bottom goes to youre return.
The blanking bolt on the right is a pressure gauge take off.So screw youre fuel pressure gauge into there.
Just behind the capnut on the top is the vacum line take off.
Hook youre vacum hose onto the top feed, and run it to youre intake manifold. Its on runner 1, if youre looking at the engine from infront of the car, its on the intake manifold on the far left hand runner just behind the fuel rail.
That any help? sorry i didnt have a picture of mine fitted.
It's 2nd hand but allegedly never fitted. Not convinced tho!
I'll have another go at it today that pic should help cheers.
No worrys bud.I fitted mine to the bulk head where the air filter used to sit.
I had to buy a new length of vacum hose as the original wasnt long enough to stretch across the bay.
Just make sure you have enough room to mount the gauge on the side , when youre deciding where to fit the regulator :p
