Taggy Posted January 29, 2013 Posted January 29, 2013 As the name suggests, I am going to have a punt that this is the same across all models as the master cylinder is the same. I need the rubber cover for where you put the fluid in, its the small one to the right of the larger brake reservoir, if you have one could you take a picture of it so i can see if its the same size. Cheers Craig
