my car should be back on the road next week and i have added these mods to the engine..
a sard ecu
front mount intercooler
hks actuator
boost controller
de-cat pipe
so i was wondering if i can now turn up the boost a little and what is a safe limit or should i 1st buy a fuel pump ?
thanks inadvance jason
a sard ecu
hks actuator
boost controller
de-cat pipe
If i were you, id run a fuel pump.Better safe than sorry. And definately want to be running one if youre going above fuel cut.
What boost you looking to run mate?
i would like to run about a bar tbh not sure how these mods will affect my car as there all going on at once so the last time i drove it it was standard
ul be fine without a pump up to about 15psi, would help to get one though to be on the safe side
eather off a suprra or a walboro fual pump
the sard ecu will remove the fual cut and increase the fualling
the car will be totaly different with this
an amial infact
ok just bought a fuel pump lol can i turn it up a little more :)
i belive 14psi = 1 bar am i right ?
as my gauge is in bar
1 bar is 14.5psi matey.
If youre running a standard ct9 turbo, it will become almost useless anything over 1bar.
So yeah, with the sard ecu, fuel pump and youre mods, it should pack quite a punch running 1bar.
You dont have it listed, but im assuming if youre running a decat, youre also running a full exhaust..In which case, next part you should be looking at should be a manifold.The turbo will spin up much more freely.
Id personally go for the walbro pump, ive heard the supra pumps dont flow quite as much, im sure enzo can back me up?
i do have a de cat pipe but not the exhaust system yet that wont be till next month any rough ideas what bhp it should be at runing 1 bar of bost with the mods listed :)
