Jarrod Posted February 10, 2013 Posted February 10, 2013 As states above I need a driveshaft only available is a non abs model but insure if will for my mk2 gt the non and driveshaft is also a gt shaft Quote
AdamB Posted February 10, 2013 Posted February 10, 2013 Yes but you will need to swap the ABS hub ring if you want to retain it. Also you will have to make sure the splines on the CV joint are the correct amount to go into your hub. Quote
Jarrod Posted February 10, 2013 Author Posted February 10, 2013 Okay cheers mate are mk2 all the same spline Quote
AdamB Posted February 10, 2013 Posted February 10, 2013 I wouldn't say they are mate, the hub may have been swapped so your best counting it. Quote
