Have you loosing the one underneath the adjuster bracket.
There's one the that hold a little piece of metal slotted into the bracket, the bolt is on the drivers side underneath
There is 3 you can loosing, the long adjuster one, one that stops it from moving and one the holds it onto the bracket that's fixed to the engine.
If its not moved for a while a hammer will be needed
