63 what? Internal diameter makes no difference. Ideally you want a filter with the largest possible surface area,however if you do this and are not external gate you will get boost creep.
Yea the diameter at the botom of the the filter
Will I really get boost creep just from shortening the air filter piping
And surely u dont have to externally gated just for this :(
Chances are you will get boost creep mate as it makes the engine more efficient. Best thing to do if you relocate the filter, is to cover up half of it or port the wastegate penny.
How handy must one be with the spanner
I'm compitent with doing most my own work so would give it a go any write up it how toos
Thanks
