Hey all, thanks to faust993 for helping with this! My live wire from my FCd is wired in and th earth is wired up but I hea I wired in to the map sensor if so which wires do I tap into?? by the way previous owner cut them two which is why I'm left with where t used to be wandering round my head!! Lol
i can find this out for you 2mro bud do you have to plug in two wires ? green and white ?
i had one of these in my car but took it out cause i got a jam ecu but ill have a look when i get the chance and tell you :)
Will be great if you can mate would help me out bucket loads.. Yeah i think it is them wires.. you snip one wire then conect one wire to the plug wire and the other to the other half of the wire you just cut.. be a great help if you could mate.
This might help
On the JAM FCC there 4 wires:
RED = 12v live - Conneted to the IGNition behind the key switch.
BLACK = Earth - Connected to the nut holding the MAP sensor.
WHITE - Connect it to the wire coming out from the MAP sensor.
GREEN - Connect it to the other half on the cut wire.
Make sure the White and Green wires are connected to the right place. Or your car will start up funny.
Cheers, im mainly tryign to find out which wire i should cut coming out of the map sensor.. i have live and earth but my green and white wire need to be plumbed into a wire which im trying to find :(
