Danza V Posted February 16, 2013 Posted February 16, 2013 Hey all, did put a topic up but it's gone anyways!I got a jam fcd on my glanza but previous owner cut two wires.. It's got the live rubbing to the 12 ignition and it's earthed.. But the two wires which are supposed to go onto the map sensor are just hanging there... Which wire do I cut on the map sensor and plumb it into? Quote
steviet Posted February 18, 2013 Posted February 18, 2013 Ok as many of you connect your JAM FCC onto the ecu, as i have done, but it didn't work as it should, so i connected it to the MAP Sensor.1st, unplug the Map sensor, theres 3 wiresCut the middle wire, not too near the plug, as you will need to use most of the wire for connection.On the JAM FCC there 4 wires:RED = 12v live - Conneted to the IGNition behind the key switch.BLACK = Earth - Connected to the nut holding the MAP sensor.WHITE - Connect it to the wire coming out from the MAP sensor.GREEN - Connect it to the other half on the cut wire.Make sure the White and Green wires are connected to the right place. Or your car will start up funny.Get some strong 2 side tape, stick the unit on the wall. Job done Quote
