Weyro Posted February 19, 2013 Posted February 19, 2013 Anyone used an SAFC to remove fuel cut? Been doing some "maths" and thinking that i will need to -15% from each rpm point after full boost at least. Worked this out by calculating that an HKS fcd at setting 8, brings 5v down to rougly 4.2v. Which is a 15% decrease. Make sense? Quote
steve-gers Posted February 19, 2013 Posted February 19, 2013 Fuel cut works on boost. If you take away 15% fuel from base higher up the range you could be running lean and car will still fuel cut anyway. Quote
Weyro Posted February 19, 2013 Author Posted February 19, 2013 (edited) the safc and sfc hyper both work by reducing the map signal, which in turn reduces fuel, the map signal is what triggers fuel cut same as an fcd, so you compensate with rrFPR Edited February 19, 2013 by Weyro Quote
steve-gers Posted February 19, 2013 Posted February 19, 2013 Ah right I see, I thought they just had some slight control of injectors. In that case as long as fuel is safe then I suppose you could use it to emilinate fuel cut, possibly safer than FCD aswell. Quote
Weyro Posted February 19, 2013 Author Posted February 19, 2013 yea should be fine, just wanted to know what % to start at so i dont hit cut while tuning, and do some damage Quote
