Roachy1994 Posted February 19, 2013 Posted February 19, 2013 what bulbs do i need for my clocks as the bulbs have gone behind them ? thanks Quote
mini1.3 Posted February 20, 2013 Posted February 20, 2013 as far as I no there 509t flattop leds cheap on ebay Quote
mini1.3 Posted February 20, 2013 Posted February 20, 2013 there cheap and fairly easy to fit get the flat top ones if not you will get certain bright spots on your clocks very anouying Quote
Roachy1994 Posted February 20, 2013 Author Posted February 20, 2013 cheers i tried getting my clocks out earlier i unscrewed all screws it didnt seem to want to pull out though are the speedo cables short or ? Quote
mini1.3 Posted February 20, 2013 Posted February 20, 2013 never had a problem in the past might be tight or jammed in Im not sure if all the cables are the same but it should unclip if you.can get your hand behind it enough Quote
Roachy1994 Posted February 20, 2013 Author Posted February 20, 2013 okey no worries will have a play tommorrow Quote
mini1.3 Posted February 20, 2013 Posted February 20, 2013 dont be to heavy handed lol Im sure Ive heard people removed the knee panel with the speaker in for more room or am I just dreaming might be worth a look mate might be able to get your hand up and see why its so tight Quote
Roachy1994 Posted February 20, 2013 Author Posted February 20, 2013 yeahhh ok ive already removed that as i wired the light in on my boost gauge earlier so yeah i will have a look tomorrow cheers dude Quote
Asad Posted February 20, 2013 Posted February 20, 2013 they are tight to get out because of the speedo cable, reach your hand back and undo it...cant remember if you just twist it off or push it in then twist... Quote
Roachy1994 Posted February 21, 2013 Author Posted February 21, 2013 i got it off after today i had to pull a little clip off the speedo cable that goes onto the clocks off then it came out Quote
