jamesglanza Posted March 2, 2013 Posted March 2, 2013 (edited) As title says both radiator fans keep cutting in and out even when the engine is cold and not up temperature.The fuse box is clicking so have changed around the fuses/relays...no change!When i unplug the single wire sensor from the thermostat housing (near the bottom rad hoses) it cuts out the fan, so im guessing its the sender for the fan? So the twin wire sensor next to the top radiator hose is for?Any body got a spare sensor or advise?cheers. Edited March 2, 2013 by jamesglanza Quote
