har-vey Posted March 6, 2013 Posted March 6, 2013 Hi all i have just fit a set of bearings to replace my gear linkage bushes and now the engagement is much better BUT and it is a big but, the gear stick doesn't return back to center. what should/ can i do to fix this regards Steve Quote
mini1.3 Posted March 7, 2013 Posted March 7, 2013 sounds like youve damaged a cable mate had the same problem on a mates after bearings check where the u shape clips hold the cable under on top of the gearbox there is a plastic bit on the casing that snaps Quote
