The Formula is :
CR = (CV + CCV) / CCV
Where CV - Cylinder Volume and CCV - Combustion Chamber Volume
Cylinder Volume = 1517cc / 4
= 379.25cc
Combustion Chamber Volume = (pi * 74.5mm2 * 2.508mm) / 4000
=10.93276 + 39cc
=49.93276cc
Plugging back into the formula gives : (379.25cc + 49.93276) / 49.93276cc
CR = 8.595 : 1
It's the virtually flat top pistons giving it the high compression.
Hope that helps mate :)
Edited by AdamB
Yes mate, I'm sure thats right, been a while since I done it. Even checked it on a few online calculator things and managed to get around that sort of CR.
If it has had headwork the cc in the head will be greater than 39cc, making more volume decreasing the CR and the flat top pistons with no dish at all contribute.
