As above really I've got 16" rota auto x et40 but with 20mm spacers to clear the brakes at the moment but I just wondered if 15" rota gt3's would fit? Probably et40 aswell! I've seen them fit over wms and willwoods but is anyone using them with ksports? Reason I want to go down to 15s is 16" tyres cost a fortune!
I doubt it unless you can get the offset down quite a bit. They need spacers when just using the WMS 4 pots with smaller discs. Then if you get the offset down a lot you'll need the arches rolling. Ball ache really.
Edited by AdamB
Im running 15" TE37's with 286 KSports and had to run 20mm spacers and i can barely fit a peice of paper in the gap! If i was you id try them on first before splashing your cash
Hummm I would try but the alloys I'm looking at are a few hours drive away :-( might just have to stick with the 16s to be on the safe side! What offset are the te37s?
