Weyro Posted March 26, 2013 Posted March 26, 2013 I want to run my TD04 setup, at 1bar on my standard FPR, what size injectors would i need to do this? I have a fuel computer, so will be able to trim. My calculations have shown that: Standard injectors are 295cc at 3bar, so run 265cc at 2.4bar(standard pressure)So injectors that are 330cc at 3bar, will flow 295 at 2.4bar. Is this correct? Cheers Quote
A L 3 X Posted March 26, 2013 Posted March 26, 2013 I'm running emanage blue with td04 on standard injectors and fpr mate Quote
Weyro Posted March 26, 2013 Author Posted March 26, 2013 (edited) im on standard ecu with a fuel controller, ive been slowly using the controller to trim the fuel and slowly raise the boost, so i might be able to avoid cut and stay on standard injectors and pressure Edited March 26, 2013 by Weyro Quote
