Suppose I like the idea of using the standard button for switching between hi-lo turbo, but I have my air filter relocated.
Does that mean if I drill an fit a metal coupler say 1/8npt to 6mm, and screw it into the alloy joiner after the air filter...I could loop the actuator hose from port 2 down onto it and keep the stock solenoid set up?
I think I also have to make a tee coming from the other solenoid port above the actuator to compressor nipple on the turbo..
So technically speaking, is it possible?! Thanks
