Hello guys just brought a safc. Struggling to work out what wires go were,
Red - live
Black - ground
Green - rpm signal
Yellow - ?
White - ?
Blue - ?
Thanks guys
Dave
Yellow and white are the wires to the map sensor. I believe blue is throttle position sensor which you won't be able to use unless you have a automatic tps I believe?
No you have to cut the wire in too. One colour goes to the ecu side and the other to the wiring loom side. Its how you adjust the fuelling. Although if you add too much fuelling the ecu will fuel cut I believe?
Ah right I get yah, I have currently a plug and play ecu but moving to a td04 turbo so its just in case I need to adjust the fueling at all
Thanks
Ah right I get yah, I have currently a plug and play ecu but moving to a td04 turbo so its just in case I need to adjust the fueling at all Thanks
I dont think the plug and play ecu will like an apexi safc messing with it, the plug and play ecu on its own should fuel the td04 just get fuelling checked.
