Just wondering if there is a specific torque setting for the hub nut as my hub was rotating freely until i tightened the hub nut up and now its hard to rotate??
Cheers
Bearing not sat square or drive shaft hiting hub take a look where the shaft goes through the hub
Have you towed the car with no shafts in?
Correct have you had a look at these things?
