Marc Posted August 26, 2007 Posted August 26, 2007 Which type of oil is best? Should i get the 10w-60 oil or which type? Also is Castrol Magnatec good gear for these 4 EFTE engines? Also how many litres does it take to fill it up as i'm thinking of doing an oil change and wondered if 4 litres is enough? Quote
Scotsep82 Posted August 26, 2007 Posted August 26, 2007 I personally use a 10-40 semi synthetic oil and change it every 2000-3000 mile as normal. Quote
paul w Posted August 26, 2007 Posted August 26, 2007 10w-40 semi is what i use.Keeping the oil in good nick by regular changes is more important than the make i reckon.Halfords oil is not too hard on the pocket for regular changes. Quote
dex Posted August 26, 2007 Posted August 26, 2007 use to put shell helix 10w 40 in my ep82 when i had one.and as others have already said reguler oil changes Quote
Marc Posted August 26, 2007 Author Posted August 26, 2007 I seen castrol oil on halfords website and it looked good. It was £37 for 4 litres. It was 10w-60 racing oil. I have a starlet manual and it says thats the oil to use for older high performance cars? Quite expensive though, the thing with cheaper oils is they are usually recycled and dont provide the protection of more expensive oils. Anyone know if 4 litres is enough for an engine if it has been drained of oil? Quote
Scotsep82 Posted August 26, 2007 Posted August 26, 2007 Oil is a personal choice discussion as many people use so many different types and some people complain that certain types don't work, so really down to personal choice.Personally i use Shell Helix 10-40 semi synth due to the fact of the age of the engine, it wasn't designed to run on fully synth and when i'm doing track racing or going to be thrashing the engine i'll use 10-50.4 Litres should be enough as it could be anywhere between 3 litres to 4 litres during a change. Quote
Barneyboy1997 Posted August 26, 2007 Posted August 26, 2007 my local toyota garage use Shell Helix 10-40 semi synth. a 4efe takes 3.2 liters so yeah you will need 4 liters Quote
