stup86 Posted August 28, 2007 Posted August 28, 2007 Morning,As far as I'm aware, for a TD04 conversion you need the following:TD04 TurboManifoldDownpipeRadiatorextended oil lines for turboHave I missed anything out?Also does anyone know if the downpipes from WEPR will fit to the standard exhaust???TaStu Quote
Hodgy Posted August 28, 2007 Posted August 28, 2007 Morning,As far as I'm aware, for a TD04 conversion you need the following:TDO4 TurboManifoldDownpipeRadiatorextended oil lines for turboHave I missed anything out?Also does anyone know if the downpipes from WEPR will fit to the standard exhaust???TaStufmic, fueling Quote
stup86 Posted August 29, 2007 Author Posted August 29, 2007 So there's nothing that i need purely to do the conversion? I'll have a FMIC and bigger injectors by the time I do the conversion so that won't be an issue.Cheers for your replies guys,Stu Quote
Guest Enzo Posted August 29, 2007 Posted August 29, 2007 dependant on kit ul need a civic raidiater aswell i would imagine Quote
carter Posted October 19, 2008 Posted October 19, 2008 the wepr kit will fit with the standard rad. i know this as i am using the standard rad. it would help with a civic rad as it would be easyer to fit and get to but you really dont need it. and yes the wepr down pipe fit perfect to the exhaust i had no problem with it lined up straight away.and it obviously all set up Quote
