Power Steering/Air Con Belt ep91
Guest dominodon
hello people my Power Steering/Air Con Belt need changeing
but i dont knw where to start does any 1 have a step buy step on changein this beltwith pic or info,
if any 1 can help that be great, :p thanks alot dan
Hello bud.
Look at this thread of mine.
It shows you how to remove the air con system..
Obviously you dont want to remove it, but it shows you the tensioner bolt you want to loosen off to remove the belt.
Pretty obvious which ones you want to loosen.
Air Con Removal
Just so you know, you need to slacken off the nuts i have circled in the 6th and 7th pictures on that page.
When there loose, you will be able to work the belt off, slide the new one on and re torque.
10 minute job, thats including a cuppa :p
