Rysmithy Posted May 4, 2013 Posted May 4, 2013 Alright guys, just a quick question my glanza sometimes revs up and its on when im driving along and doesnt stop til the car is turned off, wondered if anyone would know why? was thinking its the throttle boddies and just cleaning them, whats the best stuff for that if so? Thanks Ryan. Quote
Taggy Posted May 4, 2013 Posted May 4, 2013 sounds like the throttle is jamming, the car uses a throttle body which i mechanical, so the only way the car can rev up is if the plenum inside is open (which opens and closes when you do the throttle). Check your throttle cable isnt too tight, or sticking Quote
Danza V Posted May 4, 2013 Posted May 4, 2013 (edited) I had a similar issue. I'd check for a vac leak if its jumping about a lot, Or as you said give the tb a clean out with some carb cleaner cause the butterfly may be getting stuck open. Edited May 4, 2013 by Danza V Quote
Rysmithy Posted May 6, 2013 Author Posted May 6, 2013 Cheers guys i ckeck it all and see what happens, yeah it does jump and also its crunches going into and down into 3rd alot and just 3rd gear, any idea why? Quote
yaristurbo Posted May 7, 2013 Posted May 7, 2013 Mine did this a loose plug was wedging the peddle near redline, you'll knowwhat I mean when u see how the peddle hinges Quote
Flynn Posted May 7, 2013 Posted May 7, 2013 The throttle cable on mine and the spring had got real dry, re-oiled and then cable tied the cable up a bit and seems to have solved it! Quote
